The Wyze Cam Pan smart home camera has dropped to less than $33
The Wyze Cam Pan WYZECP1 1080p indoor smart home camera with night vision is down to $32.68 on Amazon. That's one of the lowest prices we've ever seen for this security camera. It normally sells for around $38 or more. It only dropped to around $35 for Black Friday and the holiday shopping season. The last time it dropped as low as today's deal was way back in June of last year.
This isn't the only Wyze cam on sale today, either. If you don't care about the pan function of the camera, you can get the normal Wyze Cam on sale for $23.28. That's down from a street price around $26. You can even upgrade that and grab two Wyze Cams for $40.99. That's less than $21 apiece.
Wyze Robot Vacuum
$227.78 $269.99 Save $42
The Wyze Robot Vacuum can efficiently navigate your home to clean your floors on command. It's app-enabled and can clean for nearly two hours before returning to its power station. Today's deal saves you over $40 off its full price.
Wyze Wi-Fi and Bluetooth enabled smart door lock for wireless entry
$89.99 $108.00 Save $18
Comes with a Gateway and all the mounting gear you need. Locks and unlocks automatically just by approaching the door. Knows whether your door is open or close. Uses existing deadbolt, so keep your key. Connect to Amazon Alexa for voice control.
Wyze Smart Home Starter Bundle home depot
$49.99 $90.00 Save $40
The package comes with a Wyze camera, two smart plugs, three smart bulbs, two contact sensors, a motion sensor, and an SD card. Use the free Wyze app on your phone to keep an eye on all of these devices from anywhere.
Wyze Scale
$19.54 $28.98 Save $9
Keeping track of your body fat, heart rate, and body weight becomes much easier with this Bluetooth smart scale by Wyze. It syncs your data to an app on your phone so you can see your progress over time. Plus, it can be shared with everyone at home.
Wyze Lock smart Bluetooth door lock with voice control
You can expand the storage of the Wyze Cam with microSD cards up to 32GB, and the Samsung Evo Select only go for around $7.The bundle that includes a Wyze Cam Pan and a Class 10 Wyze microSD card is currently going for $46 and often goes for $50 or more. So you're saving money going for the discounted camera and a $7 microSD card compared to that.
The Wyze camera records in 1080p video using a lens that has a 110-degree field of view. The night vision feature uses six infrared LEDs to distinguish 18 shades of gray up to 30 feet away even at the darkest time of the night. You can pan 360 degrees horizontally and tilt 93 degrees vertically for full coverage of the area in less than three seconds. You can also designate four waypoints so the camera pan scans automatically. Other features include motion detection, sound detection, and a free 14 days of rolling cloud storage. You can use the Wyze app to manage multiple cameras. Also try pairing it with your Google or Amazon smart home devices and ask to view the camera's feed.
Wyze cams are amazingly affordable and a great entry into home security. However, you should know Wyze suffered a data breach during the month of December. While it's probable they've fixed the leak by now, do your research before jumping in feet first.
