Grab TP-Link's Deco M5 mesh networking system with an Echo Dot for $150 total
TP-Link's Deco M5 mesh networking system 3-pack comes with a 3rd-generation Echo Dot smart speaker for $149.99 today on Amazon. Just the Deco M5 system by itself is currently $175, so you're saving money there and getting the $22 Echo Dot tacked on for free essentially. We've only seen the M5 drop below $150 once before anyway, so it's a great deal just for that.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
The Deco M5 replaces your Wi-Fi router and any other devices you've been using to make up for dead zones like range extenders. It can cover up to 4,500 square feet of your home in strong, stable wireless signal. TP-Link HomeCare gives the system security. Adaptive routing technology lets it choose the fastest path to keep your network running smooth. With the TP-Link Deco app, all you have to do is follow the on-screen instructions to get the system up and running as soon as possible. TP-Link covers the Deco M5 with a two-year warranty.
