Best Headphones Deals for Students in August 2021
Wheter just starting school or need to prepare for another semester, students need headphones for everything from work to play. School is definitely going to look a little different this year for just about everyone with a healthy mix of in-class training and remote learning depending on where you live. No matter what's going on around you, though, you still need to be prepared. Outfit yourself with the best gear to get your work done no matter the circumstance. And one piece of gear you should always have on you is a pair of headphones. You might even need multiple pairs for different circumstances.
If you end up having to do some work in a public space like a cafe, you may need a solid pair of noise-canceling headphones. If you are moving around a lot, like traveling from classroom to classroom, you should have a pair of true wireless earbuds you can stick in your pocket when you don't need them. Sometimes you just need a simple pair of inexpensive wired headphones to plug into your laptop. We've got all the best headphones deals rounded up right here.
Best noise-canceling headphones deals
The great thing about noise-canceling headphones is that they usually do all the other things right, too, as far as sound quality and comfort and things like that go. The active noise-canceling tech is just icing on the cake and perfect for anyone who needs to block out ambient noise. The con for these headphones is that they are usually larger than your average headphones. While they often come with a carrying case for portability, they might not be as convenient as some other options.
Best wireless headphones deals
Wireless enough that you don't have to plug them in, but not so wireless that the two pieces that go in your ears aren't connected. These headphones are portable, often have great sound, and usually fall on the budget side of affordable. You won't spend hundreds in this category, but you will get headphones that feel and sound great.
Best true wireless earbuds deals
The next evolution of the wireless headphones. The true wireless earbuds finally get rid of the last pesky cord while still offering a ton of features, including everything from active noise-canceling to wireless charging to super long battery life.
