Surface Pro update brings battery stability boost
Surface Pro is the latest Microsoft device to pick up a firmware update this month.
Following up on updates released for the Surface Pro 3 and 4 last week, Microsoft is pushing another for its latest Surface Pro this week. And while firmware updates aren't typically exciting to begin with, this one only contains a single fix focused on improving battery stability.
Here's the official look at what's new:
- Surface System Aggregator – Firmware: 234.2317.257.0 improves battery stability.
The update began rolling out on September 18 and is available for both the LTE and WiFi-only models running the Windows 10 Creators Update or later. If the Surface Pro is your machine of choice, you can grab this update now via Windows Update.
