Enhance your smart home with one of Sengled's smart bulb starter kits on sale for as low as $32
The Sengled Smart LED soft white two-bulb A19 starter kit is down to $31.99 on Amazon, the same price it was on Prime Day. If you missed the deal then, grab it now. This kit normally sells for around $40 and rarely drops from that price. We haven't seen this deal since March.
Sengled Floodlight Camera Motion Activated 1080p HD Color Night Vision Security Cam Two Way Talk Camera PAR38 E26 Base (2nd Gen), 1 Pack
$99.99 $149.99 Save $50
Sengled Pulse LED Smart Bulb with JBL Bluetooth Speaker, App Controlled Up to 8 BR30 LED Light Bulbs with Starter Kit, E26 Base, Compatible with Amazon Alexa, White, 2 Pack
$21.55 $99.99 Save $78
Sengled Element Color Plus Smart A19 LED bulb starter kit
$109.99 $119.99 Save $10
Sengled Smart LED Multicolor A19 2-bulb Starter Kit
$47.95 $69.99 Save $22
$99.99 $119.99 Save $20
Sengled has a couple more kits on sale right now, too. Grab the 4-pack starter kit on sale for $47.99. That's $12 off its regular price.
You can also get the multi-color 4-bulb starter kit at a low price of $95.99. That's a huge drop compared to its normal $140 price. Even when it goes on sale, it usually only drops to $120. The last time it dropped below $100 was on Black Friday.
Each of these starter kits comes with a smart hub that connects to your 2.4 GHz wireless network. You can then connect the bulbs to the hub and the hub to your smart home, whether it's Alexa or Google powered. You can also use the Sengled Home App to schedule all the smart features. Create scenes, set routines, and power the bulbs from anywhere. Monitor your energy efficiency through the Sengled app, too. The hub can support up to 64 Sengled bulbs, so you can add more if you want.
