Save $35 on Anker's PowerCore USB-C charger and keep your gear powered up
The Anker PowerCore+ 26800mAh Power Delivery USB-C battery charger has dropped to $104.99 through Amazon. This is a unique low price and the best deal we've seen since last year's Black Friday sales. The charger normally sells for around $140 and can even jump as high as $190. You won't find a better price anywhere else, and it even comes with the cable and the wall charger you need to get plugged in and powered up right away.
This deal on the PowerCore+ is part of a larger sale going on at Amazon covering several Anker accessories. If you need a wireless charger or a power strip with multiple USB ports or even just some cables to connect to charging equipment you already have, check out the full sale and see all the ways you can save. Everything is down to a low price, but it is a one-day sale so act quickly.
This charger is large enough to charge your laptop and with a 45W USB-C port, it actually can. You'll also get two 15W USB-A ports that you can use for your mobile devices. With a 26800mAh battery capacity, you'll be able to provide enough juice for all of your devices. That's enough to fully charge a Dell XPS 13 or recharge your phone multiple times over.
The bundle includes a 60W USB-C wall charger, which means you get the fastest possible recharge times as well. Get your portable battery up and running in less than three hours thanks to Power Delivery. Then keep your gear up for a lot longer than that while you're away from wall outlets and places to plug in.
The device even comes with a travel pouch so you can keep the battery, wall charger, and USB-C cable all together while you're on the move. Anker covers it with an 18-month warranty.
