Charge two devices at once with RAVPower's 10000mAh power bank down to $12
The RAVPower 10000mAh ultra-compact high-speed portable charger drops down to just $11.79 thanks to this 20% off promotional link and a $1 off on-page coupon. Without either discount, the power bank is going for $16. That's already a $4 discount since it regularly sells for $20.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
The 10000mAh capacity is plenty of juice, and you'll be able to recharge your smartphone at least a couple times over. Use the two USB-A ports to charge two devices simultaneously. The device is built to be both ergonomic and aesthetically pleasing with rounded corners and a thoughtful design. It also has built-in safety features to prevent things like short-circuits or over-heating.
