This portable 5,000mAh power bank with wireless charging is now under $30
Sale 26731 Primary Image
Source: Stack Commerce (Image credit: Source: Stack Commerce)
Most power banks will only charge your devices if you remember to bring a charging cable. In contrast, the ChargeHubGO+ All-in-One Power Bank has two cables and a wireless charging pad built-in. It's a great option for traveling light, and you can get it now for $29.99 when you use code LIMITLESS25 for 25% off.
https://www.youtube.com/embed/Ppub__y9_tM
Carrying a small back-up battery in your pocket isn't a problem. But add multiple cables for your various devices, and the setup doesn't seem so pocket-friendly after all.
You won't face such problems with ChargeHubGO+. Measuring just 0.75 inches thick, this versatile power bank can handle Lightning, micro-USB, and Type-C devices without help. One side of the case doubles as a 5W wireless charging pad, and you get a USB port for good measure.
Thanks to SmartSpeed technology, ChargeHubGO+ can handle up to 15W total output. The power bank has a generous capacity of 5,000mAh, and the product has passed stringent safety and durability tests.
It's usually priced at $39.99, but you can get ChargeHubGO+ now for $29.99 with code LIMITLESS25.
ChargeHubGO+ All-in-One Power Bank – $29.99 with code LIMITLESS25
See Deal
Prices subject to change
Do you have your stay-at-home essentials? Here are some you may have missed.
CATEGORIES
WinC Staff
