Cover your home in a Wi-Fi blanket with the Netgear Orbi mesh system on sale for $269
The Netgear Orbi RBK50 whole home mesh Wi-Fi system with one router and one satellite is on sale for $269.42. This system goes for as much as $330 pretty regularly, but the street price seems to be around $310. Today's deal is a match for the lowest we've seen in more than a year.
Netgear CM1000 DOCSIS 3.1 cable modem
$129.99 $170.00 Save $40
Compatible with Comcast, Spectrum, Cox and most cable providers. Has DOCSIS 3.1 and supports up to 1 Gigabit internet speeds. Can work with any Wi-Fi router as well. Rental fees can cost up to $170 per year, so it pays for itself.
Netgear AX1800 Wi-Fi 6 4-stream wireless router
$66.21 $90.00 Save $24
Can handle speeds up to 1.8Gbps over wireless and works with Wi-Fi 6 devices like the iPhone 11 or Galaxy S10. Use the Nighthawk app for easy setup and management, including testing your internet speed and data usage.
Netgear Nighthawk MK62 AX1800 whole mesh Wi-Fi 6 system router and extender
$167.12 $200.00 Save $33
Includes one router and one satellite extender to cover up to 3,000 square feet in Wi-Fi. Get four powerful streams with speeds up to 1.8Gbps and reliable performance for more than 25 devices with MU-MIMO Smart Connect. Includes Ethernet ports.
NETGEAR 28-Port Gigabit Ethernet Smart Managed Pro PoE Switch (GS728TPP) - with 24 x PoE+ @ 380W, 4 x 1G SFP, Desktop/Rackmount, and ProSAFE Lifetime Protection
$374.09 $499.99 Save $126
Netgear 16-port Gigabit Ethernet unmanaged switch
$156.06 $189.99 Save $34
The RBK50 comes with one router and one satellite extender. That's enough coverage for any home up to 5,000 square feet. Your phone won't have to reconnect or drop the signal and pick it back up as it moves around the house. It'll just work. The Orbi system uses tri-band wireless technology and is powerful enough to handle multiple network connections at once. It even comes with the Orbi app so you can do speed tests, set up parental controls, and more.
