Minecraft guide: How to fix cross-play and multiplayer issues for the Bedrock Edition
Village at sunset
Village at sunset (Image credit: Windows Central)
Minecraft is often considered the poster child for forward-thinking gaming features like cross-platform multiplayer play, and a single code base that spans all of your devices. However, such an ambitious undertaking is bound to come with a plethora of bugs and roadblocks that can prevent you from having an enjoyable experience. Fortunately, there's usually a workaround if you're diligent enough to look for it. Here's what we've found out so far.
How to fix multiplayer issues in Minecraft
Everyone who games has likely encountered some kind of problem or another that's interfered with their fun time. Especially in regards to multiplayer games, any number of factors can come into play and complicate things. I'm here to hopefully shed some light on those issues when it comes to Minecraft, and find solutions anyone can take advantage of. Most problems exist in three categories: your game, your account, and your hardware, ranging from as simple as a single toggle all the way to diving deep into your Wi-Fi router's configuration. Let's dive right in!
Issues with Minecraft
So many pretty colors
The most common issues one might have with multiplayer in Minecraft are usually something to do with Minecraft itself. More specifically, either the worlds themselves aren't set to allow multiplayer, or the game hasn't been set up to allow multiplayer with players from other platforms. Both are pretty easy fixes. Let's tackle them one at a time.
Each world you create has its own settings, so you can have full control over which worlds your friends have access to, and which ones you wish to keep all to yourself. If you have a world that isn't allowing multiplayer, here's what you need to do:
  1. Open Minecraft. No matter what platform you're playing on, this fix requires that you be inside of Minecraft.
  1. Find the world you want to edit. Hit the "Play" button and make sure you're in the "Worlds" tab. Find the world you want to edit in the list shown below.
  2. Hit the edit button. It's the one that looks like a pencil in motion. It'll be located to the right of the world's name.
  1. Make sure the "Multiplayer Game" toggle is turned on. If you navigate down to the "Multiplayer section, the option at the top should be a toggle to allow multiplayer. This section also lets you set who can join.
  2. Try it out! Once your settings are correct, try letting your friends join your multiplayer game now.
If the problem you're having with your game is playing with people on other platforms, then you might not have set up cross-play on your device. If you're playing on Xbox or Windows 10, the fix is as easy as making sure you're signed into a valid Xbox Live (or Microsoft) account. If you're playing on the Nintendo Switch, this guide will help you out. If you're playing on Playstation 4, this is the guide for you. If neither of those guides had the answers you needed, the next section probably will.
Issues with accounts
A mountain with a waterfall
Cross-play and multiplayer often require having the correct accounts and the correct settings to compliment those accounts. Making sure these are set up properly is an excellent way to cross off another couple of obstacles when you're having issues getting online. There are usually two accounts you'll need to worry about: your Microsoft Account and the account for the platform you're playing on.
A Microsoft Account is what connects Minecraft: Bedrock Edition across all platforms, and it's also what enables multiplayer with players on other platforms. This account is doubly crucial on Xbox and Windows 10 devices, as your Microsoft Account pulls double duty and handles absolutely everything to do with multiplayer in the form of an Xbox Live account. By default, your Microsoft Account will be set up correctly to allow cross-play in multiplayer. If you're under 18, though, there's a chance your Microsoft Account is blocking multiplayer access.
Here's all the information you might need to have:
Issues with hardware
Tis a building
If all else fails, the issue may lie with your network hardware. This is the last resort, since it does require a fair bit of work and a little bit of technical know-how to pull of, but you should only have to do this if you're having issues with playing online at all. If your home's internet network hasn't been configured correctly, a lot of functions like voice chat, creating parties, or playing online at all might be restricted. If you use a VPN, or Virtual Private Network, to monitor and secure your internet activities, that may also be the culprit here. Let's tackle them one at a time.
To configure your router correctly, do the following:
  1. Make sure you have a Windows PC nearby. We need to find out some information about your network, and a Windows computer is your best bet.
  2. Open the Command Prompt. If you don't know how to find it, just type "cmd" into the search box, and it should be the first option.
  3. Type in the following: "ipconfig/all." Quotation marks aren't necessary. This brings up a bunch of intimidating information about your network.
  4. Look for the "Default Gateway." It'll likely be near the bottom of the largest section of information. Some routers will also refer to this as the "IPv4 Gateway." The numbers usually look a little like this: "192.168.0.0."
  5. Open your favorite browser. Put those numbers exactly as you see them into your browser's address bar. This will bring you to the settings for your router.
  6. Put in your router password. For most routers, this usually defaults as just "admin," but if that isn't correct and you don't know what it is, you may have to contact support for your router's manufacturer.
  7. Search for the UPnP section. This will vary from router to router. For some, it'll be under the "Administration" section. For others, it'll be under "Advanced Setup." The names vary, but it should be there.
  8. Make sure UPnP is turned on. This changes your network from strict to open.
  9. Save your changes. This will also vary from router to router. It might be an "Apply" button, or a "Save" button either at the top or the bottom of your screen.
Finally, if you use a VPN on top of your internet network, you need to make sure that P2P (partner-to-partner) connections are allowed. Most VPN's will have dedicated servers that allow P2P, so consult with your VPN settings or application to make sure you're using the best server for you. Although, to be honest, VPN's aren't great for online gaming, since they introduce additional latency and lag on top of your network, so you might consider turning your VPN off temporarily when you're preparing for a bout of gaming.
All better now
Some happy villagers
Minecraft is a glorious (and gloriously complicated) game that strives to unite gamers on all platforms together. That also means gamers on platforms, all shapes and sizes run into various issues preventing them from getting online. Hopefully, this guide nails the vast majority of them, and lets you narrow down exactly what's causing the problem. If this guide didn't work for your problem, let us know, and we'll do our best to find a creative solution for you. If it did work, what are you still reading for? Go and play!
Have you run into any other Minecraft issues? Have you found a workaround for them? Sound off in the comments below!
CATEGORIES
Zachary Boddy
Staff Writer
Latest in Minecraft
Screenshot of one of the new flat world presets in Minecraft.
Minecraft testing new flat world presets and a better way to locate your friends in-game
Side-by-side comparison of Minecraft's "Vibrant Visuals" upgrade toggled on and off.
How exactly does Minecraft's Vibrant Visuals upgrade change the game? Here are side-by-side comparisons, and everything else you need to know
Screenshot from the third 'A Minecraft Movie' trailer.
McDonald's is celebrating the Minecraft movie's release with new Happy Meals, toys, and even a special sauce
Key art for Minecraft Live (Mar. 2025).
I kept track of everything announced during the latest Minecraft Live so you don't have to
Screenshot of Minecraft Live (Mar. 2025).
The Minecraft movie makes an appearance at Minecraft Live with exclusive footage
It took years, but Minecraft is finally getting a visual upgrade to bring the graphics we've been wanting
Latest in How-to
Atomfall
Can I play Atomfall on Steam Deck, ROG Ally, and other gaming handhelds?
Windows 11 answer file
How to easily create an unattended answer file for Windows 11
The First Berserker: Khazan
Is The First Berserker: Khazan on Xbox Game Pass?
Clair Obscur: Expedition 33
Is Clair Obscur: Expedition 33 on Xbox Game Pass?
A close-up of Hazel in South of Midnight
Is South of Midnight on Xbox Game Pass?
Atomfall screenshot
Atomfall: How to grab the best melee weapon and melee perk right away
