The LucidSound LS35X on sale for $116 are one of the best wireless headsets you can buy
The LucidSound LS35X wireless surround sound gaming headset is down to $115.50 on Amazon. This is the lowest price we've ever seen. We even just shared a deal in early August when it dropped to around $147, so you can see just how much better life has gotten for LS35X fans. The headset normally sells for around $180.
WIndows Central gave the LS35X a 5 out of 5 last November and labeled it "The Best." The reviewer, Jez Corden, said "All things considered, there's really nothing I'd consider a deal breaker here. The sound quality is excellent, the mic quality is exemplary, the cooling gel-infused earcups are sublime, and the outward design and construction are top-notch." Corden added the headset has "great battery life and tremendous Xbox One integration, with one-button connectivity and on-screen battery notifications."
It's worth noting that the headset really really requires a firmware update before you use it. Don't skip that because you might not be as happy with it if you do.
While licensed to work with the Xbox, you can actually use this headset on just about any platform including the Nintendo Switch, PlayStation 4, PC, Mac, iOS, and Android. When you use it on the Xbox One, you'll be able to sync wirelessly with one button. It connects directly the same way an Xbox One controller does and configures automatically.
The headset features a dual mic system that includes a flexible boom mic and an integrated mic that activates automatically if you decide to remove the boom, making it great for use on the go or with mobile devices. The boom mic includes advanced noise cancellation so your friends will hear only your beautiful voice. The headset comes with a travel case and a one-year warranty.
