Score the Logitech MX Sound Bluetooth speakers down to $50 for Prime Day
The Logitech MX Sound 2.0 multi-device Bluetooth stereo speakers are down to $49.99 on Amazon. The street price for these speakers is around $80, but they also have gone as high as $100 recently. Today's deal is now the lowest price we've seen, even though we've shared a few deals in the past. It never dropped below $60 before.
Logitech G Pro X Superlight wireless gaming mouse
$137.98 $150.00 Save $12
This mouse was made in collaboration with leading esports pros,, which means it's designed with intense and competitive gaming in mind. It weighs less than 63 grams. The Hero Sensor is designed for best possible performance.
Logitech G640 large cloth gaming mousepad black
$24.99 $40.00 Save $15
Gives the right amount of resistance to your mouse with low DPI gaming so you can be more precise. Surface provides a consistent texture for an even translation of mouse to cursor movement. Rubber bottom keeps it from slipping.
Logitech G613 Lightspeed wireless mechanical gaming keyboard black
$63.99 $79.00 Save $15
Includes Bluetooth and Logitech's Lightspeed wireless tech for a 1ms report rate. Uses Romer G mechanical switches that are very durable and can survive 70 million clicks. Has six programmable G keys and lasts up to 18 months on two AA batteries.
Logitech G305 LightSpeed wireless gaming mouse
$39.99 $60.00 Save $20
Includes Logitech's wireless USB receiver for a speedy connection. LightSpeed tech makes the responsiveness less than 1 millisecond. Includes a 12,000 DPI sensor, 250 hours of battery life, LED optical scanning, 6 programmable buttons, and more.
Logitech G502 Hero high performance gaming mouse black
$39.99 $50.00 Save $10
Uses high-performance 16K DPI sensor. Huge adjustable range as well. Has 11 customizable buttons with onboard memory so you can store different combinations per game. Has RGB lighting and LightSync to pair with other gear.
I was looking for computer speakers recently, and the MX Sound were on my shortlist. Unfortunately, they were $100 when I was looking to make a purchase. I probably would have bought them if they were this low. Logitech's Easy-Switch lets you move between audio sources easily. All you have to do is pause the audio from one source and press play on the next. If you're sitting at your computer and want to go mobile, you can just get up and keep listening. The 24-watt peak drivers have balanced audio designed to play more powerfully than most speakers this size. They pair with any Bluetooth device and allow quick volume adjustments. The back-lit controls are motion activated as well. Users give them 3.9 stars based on 90 reviews.
This sale is part of a larger collection for Prime Day featuring computer components, monitors, accessories, and more down to low prices.
