Lian Li's Odyssey X is a transforming PC case built for water cooling
The Odyssey X can swap between three modes to deliver different looks and airflow setups.
- Lian Li announced the Odyssey X PC case today.
- The case can transform into three different configurations with different airflow setups.
- The Odyssey X is available starting today for $500.
Lian Li announced the Odyssey X PC case that can transform into three configurations to adjust airflow. In addition to altering how air flows through the case, the different modes each provide a different look. Lian Li already makes the best PC case on the market. Now, people have a unique option from the same company in the Odyssey X. The new case is available starting today for $500.
When shipped, the Odyssey X is in Dynamic mode, which supports up to two 360 mm radiators. It includes parts needed to switch it to Dynamic-R (rotate) mode, which rotates the motherboard tray to improve GPU cooling. The rotated mode also swaps access to the motherboard's ports to the top of the case. Dynamic-R mode supports a 480 mm radiator and a 380 mm radiator or two 360 mm radiators.
The final configuration is called Performance mode. It flips the case 90 degrees to deliver better airflow. It also supports either two 360 mm radiators or a 480 mm radiator and a 380 mm radiator.
No matter what configuration the Odyssey X is in, the case supports water cooling components. It fits radiators up to 480 mm, nine 120 mm fans, or seven 140 mm fans.
In addition to having three configuration options, the Odyssey X is available in two colors, black or a black/silver combination.
Built for airflow and water cooling
This case can transform between three configurations to deliver different looks and airflow setups. It's also available in two different colors.
Sean Endicott is a tech journalist at Windows Central, specializing in Windows, Microsoft software, AI, and PCs. He's covered major launches, from Windows 10 and 11 to the rise of AI tools like ChatGPT. Sean's journey began with the Lumia 740, leading to strong ties with app developers. Outside writing, he coaches American football, utilizing Microsoft services to manage his team. He studied broadcast journalism at Nottingham Trent University and is active on X @SeanEndicott_ and Threads @sean_endicott_.
