HP announces its first consumer creator display, the HP U28 4K HDR Monitor
HP's latest display is flexible and focuses on color accuracy.
- HP announced the HP U28 4K HDR Monitor.
- It's HP's first consumer creator display.
- The HP U28 4K HDR Monitor will be available in December for $449.
HP announced the HP U28 4K HDR Monitor today. It's the first-ever consumer creator display from HP, and it focuses on color accuracy and flexibility. The 28-inch 4K HDR monitor starts shipping in December for $449.
HP designed the HP U28 4K HDR Monitor for creators. It has color presets for creators, is factory calibrated for color accuracy, and has an ultra-wide color range. It covers 100 percent sRGB and 93 percent DCI P3. The monitor supports HP Eye Ease, which filters out blue light without adding an orange tint.
The HP U28 4K HDR Monitor is fully adjustable, allowing you to tilt, pivot, and swivel the display to fit different workflows. The display pivots up to 90 degrees, so you can use it in portrait or landscape mode.
Category | Spec |
Display size | 28-inch |
Resolution | 4K UHD (3840 x 2160), 16:9 |
Panel type | IPS |
Refresh rate | 60Hz |
Response time | 4ms GTG with overdrive |
Contrast | 1000:1 |
Brightness | 400 nits |
Color | 100 percent sRGB93 percent DCI P3 |
Connectivity | DisplayPort 1.2HDMI 2.0USB-C with PD2x USB-A 3.1 Gen 1Headphone out |
Dimensions | 25.08 in (L) x 7.47 in (W) x 20.92 in (H) (63.71 cm (L) x 18.99 cm (W) x 53.14 cm (H)) |
Price | $449 |
Availability | December 2020 |
The monitor can connect to your computer with a single USB-C cable. When connected, it can charge a computer up to 65W, so your device can be fully charged when you take it away from your desk.
In addition to being HP's first-ever consumer creative display, the HP U28 4K HDR Monitor is also the world's first consumer display with ocean-bound plastic materials.
This 28-inch 4K HDR monitor is built for creators. It covers 100 percent sRGB and has a blue light filter that doesn't add an orange tint to your screen.
Sean Endicott is a tech journalist at Windows Central, specializing in Windows, Microsoft software, AI, and PCs. He's covered major launches, from Windows 10 and 11 to the rise of AI tools like ChatGPT. Sean's journey began with the Lumia 740, leading to strong ties with app developers. Outside writing, he coaches American football, utilizing Microsoft services to manage his team. He studied broadcast journalism at Nottingham Trent University and is active on X @SeanEndicott_ and Threads @sean_endicott_.
