How is Razer Blade 15 Studio Edition battery life?
What you need to know about the battery
The Razer Blade 15 Studio Edition is equipped with a very large 80Wh battery, which may at first make you think the device has a long battery life. However, the truth is that it needs a big battery just to achieve average battery life due to how much power is underneath the laptop's hood. Since the device is designed with workstation-level hardware, it takes a lot of power to keep it running.
For general use, you'll be able to get anywhere between 5-6 hours of use out of the Razer Blade 15 Studio Edition before needing a charge. However, if you put its hardware to work by performing tasks like video editing or 3D rendering, you'll deplete the battery faster. As such, it would be best to keep the device's charger on-hand and to stay near an outlet when possible.
Why you should get the Razer Blade 15 Studio Edition
The Razer Blade 15 Studio Edition is one of the most powerful portable workstation devices available right now. Armed with a superpowered NVIDIA Quadro RTX 5000 GPU, a beefy Intel i7-9750H CPU, and 32GB of RAM, it's an absolute monster of a laptop that can handle any creative task, from high-quality video editing to powering civil engineering apps and everything between.
Complementing the device's immense hardware power is its fantastic 4K 60Hz OLED touch display that sports HDR support and a perfect 100% DCI-P3 color accuracy. This screen allows you to view your projects in stunning detail, giving you the ability to evaluate every pixel of your work. The 1TB solid-state drive (SSD) is perfect for storing your work, too, and the four USB ports (including one Thunderbolt 3) allow you to transfer data to and from the laptop with ease.
Aside from being perfect for creative tasks, the Razer Blade 15 Studio Edition's top-notch specs make it a stellar gaming device as well (though that's not what it's meant to be). You can download the NVIDIA GeForce Experience software and use it to swap between studio and gaming drivers at will, enabling you to play today's best-looking games if you feel like taking a break from working.
All the power you need
Between the killer hardware specs and the stunning 4K display, the Razer Blade 15 Studio Edition is an out-of-this-world choice for photo and video editing, as well as any other creative task.
