Razer Blade 14 now available in quartz pink featuring RTX 3070 Ti and Ryzen 9 6900HX
Razer just launched a new color option for its popular Blade 14 laptop.
- The Razer Blade 14 can now be ordered in quartz pink.
- The quartz color option is available for the model with an NVIDIA RTX 3070 Ti and an AMD Ryzen 9 6900HX.
- Razer Skins were also announced today, allowing people to apply their color pattern of choice to their favorite Razer laptops.
The Razer Blade 14 is one of the best Windows laptops around. Now, it's available in a new color option with the latest specs from AMD and NVIDIA. Today, Razer announced that the Blade 14 is available in quartz pink. The limited edition model in that color features an NVIDIA GeForce RTX 3070 Ti and an AMD Ryzen 6900HX.
Spec | Razer Blade 14 |
CPU | AMD Ryzen 9 6900HX |
GPU | NVIDIA RTX 3070 Ti (8GB VRAM) |
Memory | 16GB DDR5-4800MHz (fixed) |
Storage | 1TB PCIe Gen 4 SSD (upgradeable to 2TB) |
Display | 14-inch QHD 165Hz, 2560 x 1440 |
Ports | 2x USB-A2x USB-C1x Power Port1x HDMI 2.11x 3.5mm audio jack1x Kensington lock port |
Biometrics | 1080p IR webcam (Windows Hello compatible) |
Connectivity | Wi-Fi 6EBluetooth 5.2 |
Battery | 61.6WHr |
Weight | 3.92 pounds (1.78kg) |
Dimensions (HxWxD) | 0.66 x 12.59 x 8.66 inches(16.8mm x 319.mm7 x 220mm) |
Price | $2,599.99 |
If you love colors but don't want a new laptop, Razer's other announcement from today will be a welcome one. The company announced Razer Skins, which can be applied to laptops in various colors and patterns. Razer Skins start at $25 and range up to $60 for full coverage.
Razer Blade 14 in quartz | $2,600
The popular Razer Blade 14 is now available in quartz pink. The quartz model features an AMD Ryzen 6900HX CPU and an NVIDIA GeForce RTX 3070 Ti GPU. Models with different specs are available if you're open to getting the laptop in black.
Sean Endicott is a tech journalist at Windows Central, specializing in Windows, Microsoft software, AI, and PCs. He's covered major launches, from Windows 10 and 11 to the rise of AI tools like ChatGPT. Sean's journey began with the Lumia 930, leading to strong ties with app developers. Outside writing, he coaches American football, utilizing Microsoft services to manage his team. He studied broadcast journalism at Nottingham Trent University and is active on X @SeanEndicott_ and Threads @sean_endicott_.
