Lenovo unveils the Slim Pro 9i, a thin-and-light laptop with a mini-LED display and NVIDIA RTX 40-series graphics
Lenovo packed the latest high-end specs for creators into the new Slim Pro 9i.
- Lenovo just announced the Slim Pro 9i, a new flagship laptop from its family of devices.
- The laptop runs on up to a 13th Gen Intel Core i9 CPU paired with up to NVIDIA GeForce RTX 4070 laptop graphics.
- The Lenovo Slim Pro 9i is available in a 14.5-inch and a 16-inch model.
- Lenovo also announced its Slim Pro 7 and Slim 7i laptops today.
Lenovo just unveiled a new flagship laptop, the Slim Pro 9i. The thin-and-light PC features NVIDIA GeForce RTX 40-series graphics and Lenovo X Power, which is a set of hardware and software features that work side-by-side to help creators get a smooth experience. Those graphics are paired with up to a 13th Gen Intel Core i9 processor.
Available in both 14.5-inch and 16-inch models, the Lenovo Slim Pro 9i tops the Lenovo Premium Suite of laptops, which also includes the newly announced Slim Pro 7.
Thanks to its high-end specs, the Slim Pro 9i should be able to handle demanding professional workloads, such as 3-D modeling, graphic design, and other creator tasks.
Both sizes of the Slim Pro 9i come with multiple display options. The smaller model has either a 14.5-inch 3K LCD screen with a 120Hz refresh rate or a 14.5-inch 3K Mini-LED display with a refresh rate of 165Hz.
The larger model can feature either a 16-inch 3K LCD panel with a 165Hz refresh rate or a 16-inch Mini-LED screen with a resolution of 3K and a refresh rate of 165Hz.
Slim Pro 9i | 14.5" | 16" |
Processor | Intel Core i9-13905HIntel Core i7-13705HIntel Core i5-13505H | Intel Core i9-13905HIntel Core i7-13705H |
Operating system | Windows 11 | Windows 11 |
Graphics | Intel Iris Xe DISNVIDIA GeForce RTX 4050 laptopNVIDIA GeForce RTX 4060 laptopNVIDIA GeForce RTX 4070 laptop | NVIDIA GeForce RTX 4050 laptopNVIDIA GeForce RTX 4060 laptopNVIDIA GeForce RTX 4070 laptop |
Memory | 16 / 32 / 64 GB LPDDR5X-6400 | 16 / 32 / 64 GB LPDDR5X-6400 |
Storage | 512 GB / 1 TBPCIe Gen4 M.2 | 512 GB / 1 TBPCIe Gen4 M.2 |
Display | 14.5" LCD 3K 120Hz 16:10 400-nits14.5" Mini-LED 3K 165Hz 16:10 1200-nits | 16" LCD 3K 165Hz 16:10 400-nits16" Mini-LED 3K 165Hz 16:10 1200-nits |
Camera | FHD IR webcam + ToF (LCD)5MP IR webcam + ToF (Mini-LED) | 5MP IR webcam + ToF |
Audio | 4x Dolby Atmos speakers | 6x Dolby Atmos speakers |
Connectivity | Wi-Fi 6EBluetooth 5.1 | Wi-Fi 6EBluetooth 5.1 |
Ports | 1x Thunderbolt 4 3.2 Gen2, DP 1.4, PD 3.02x USB-A 3.2 Gen11x HDMI 2.11x SD card reader | 1x Thunderbolt 4 3.2 Gen2, DP 1.4, PD 3.01x USB-A 3.2 Gen11x HDMI 2.11x SD card reader |
Battery | 75Whr | 75Whr |
Dimensions | 327 x 224 x 16.9 mm (LCD)327 x 224 x 17.6 mm (Mini-LED) | 362 x 245 x 17.9 mm (LCD)362 x 245 x 18.16 mm (Mini-LED) |
Weight | Starting at 1.65 kg (LCD)Starting at 1.7 kg (Mini-LED) | Starting at 2.06 kg (LCD)Starting at 2.23 kg (Mini-LED) |
The Slim Pro 9i features an upgraded keyboard with 1.5mm dish cap keys that have an anti-grease coating to reduce fingerprints and smudges. Those keys will also respond faster to input than previous laptops from the lineup.
All the Lenovo Premium Suite laptops, including the Slim Pro 9i, have four microphones, four noise-reducing speakers, quiet fans, and large trackpads.
The lineup also comes with the Lenovo AI Engine+, which dynamically adjusts power efficiency and performance settings using artificial intelligence. Lenovo Intelligent Sense and Integrated Security are both included on all the laptops in the suite as well.
Tidal Teal and Storm Grey versions of the Slim Pro 9i will be available. The laptop starts at $1,700 for the 14.5-inch model and $1,800 for the 16-inch version. All variants of the laptop are expected to ship in May 2023.
Lenovo Slim Pro 7 & Slim 7i
Lenovo also announced its Slim Pro 7 and Slim 7i laptops today. They also come with Lenovo AI Engine+ and the other features that extend across the entire Slim laptop lineup broken down above.
The Slim 7i is designed for creators on the go. It runs on a 13th Gen Intel Core processor and is available in Misty Grey or Storm Grey.
Lenovo Slim 7i | 14" |
Processor | Intel Core i7-1360PIntel Core i5-1340PIntel Core i7-1260PIntel Core i5-1240P |
Graphics | Intel Iris |
Memory | 8 / 16 GB LPDDR5 |
Storage | 512 GB / 1 TBPCIe M.2 |
Display | 14" LCD 2.8K 120Hz 16:10 400-nits14" LCD 2.2K 60Hz 16:10 300-nits14" OLED FHD+ 60Hz 16:10 400-nits |
Camera | FHD IR webcam + ToF shutter |
Audio | 2x Dolby Atmos speakers |
Connectivity | Wi-Fi 6 / 6EBluetooth 5.1 |
Ports | 1x USB-C 4, DP 1.4, PD 3.01x USB-C 3.2 Gen 11x USB-A 3.2 Gen 11x HDMI 2.1 |
Battery | 65Whr |
Dimensions | 312 x 221 x 41.9 mm |
Weight | Starting at 1.31kg |
The Slim Pro 7 pairs up to an AMD Ryzen R7 CPU with up to an NVIDIA RTX 4050 graphics. It can also ship with an RTX 3050 GPU for those that need a solid graphics card but don't need the latest GPU.
The 14.5-inch laptop has up to a 3K display with a 120Hz refresh rate that can reach 400 nits of brightness.
The PC also includes four microphones with voice ID noise cancelation and four speakers. An IR camera, Time of Flight sensor, and the laptop's camera shutter help ensure your privacy.
Lenovo Slim Pro 7 | 14.5" |
Processor | AMD Ryzen R5-7535HSAMD Ryzen R7-7735HS AMD Ryzen R5-7640HSAMD Ryzen R7-7840HS |
Graphics | UMA integrated Radeon graphicsNVIDIA GeForce RTX 3050 laptopNVIDIA GeForce RTX 4050 laptop |
Memory | 16 GB LPDDR5/X-6400 |
Display | 14.5" glass LCD 2.5K 90Hz 16:10 350-nits14.5" matte LCD 2.5K 90Hz 16:10 350-nits14.5" LCD 3K 120Hz 16:10 400-nits |
Connectivity | Intel Wi-Fi 6EBluetooth 5.1 |
Ports | 1x USB-C 4 Gen1, DP 1.4, PD 3.01x USB-C 3.2 Gen1, DP 1.4, PD 3.01x USB-A 3.2 Gen 11x HDMI 2.1 |
Battery | 73Whr with Rapid Charge Express |
Dimensions | 326 x 227 x 15.6 mm |
Weight | Starting at 1.49 kg |
Sean Endicott is a tech journalist at Windows Central, specializing in Windows, Microsoft software, AI, and PCs. He's covered major launches, from Windows 10 and 11 to the rise of AI tools like ChatGPT. Sean's journey began with the Lumia 740, leading to strong ties with app developers. Outside writing, he coaches American football, utilizing Microsoft services to manage his team. He studied broadcast journalism at Nottingham Trent University and is active on X @SeanEndicott_ and Threads @sean_endicott_.
- Ben WilsonSenior Editor
