Kickstarter campaign launches for DUOVER, a Moleskine-style case for Surface Duo
DUOVER case for Surface Duo
(Image credit: DUOVER)
  • A Kickstarter campaign just launched for a foldable case for the Surface Duo called the DUOVER.
  • The case is inspired by the look of a Moleskine notebook and can be folded into several postures to support the Duo.
  • The DUOVER also features a spot to magnetically attach a Surface Pen.
The downside of the DUOEVER is that it's in the early stages of development. A campaign for the DUOEVER just launched on Kickstarter.
There are a few different pledge options for the DUOEVER, including an early bird pledge of $19 that will get you the case for less than its planned price of $39. You can also get a custom engraved DUOEVER case if you pledge $39.
The Kickstarter page outlines what will be done if the campaign reaches its financial goals:
  • Source production equipment and specialized materials
  • Establish potential relationships with manufacturers
  • Add extra features and design tweaks that are currently in development
  • Launch the Surface Duo 2 version of The Duover Case (there will be a simultaneous release of both versions)
As with all Kickstarter and crowdfunded projects, you should take caution before pledging any money. Products on Kickstarter are not guaranteed, so in some cases it's best to hold off from investing. We plan to follow up with the DUOVER as it progresses through its campaign.
Sean Endicott
News Writer and apps editor
Sean Endicott is a news writer and apps editor for Windows Central with 11+ years of experience. A Nottingham Trent journalism graduate, Sean has covered the industry’s arc from the Lumia era to the launch of Windows 11 and generative AI. Having started at Thrifter, he uses his expertise in price tracking to help readers find genuine hardware value.
Beyond tech news, Sean is a UK sports media pioneer. In 2017, he became one of the first to stream via smartphone and is an expert in AP Capture systems. A tech-forward coach, he was named 2024 BAFA Youth Coach of the Year. He is focused on using technology—from AI to Clipchamp—to gain a practical edge.
