Corsair's most popular products are discounted for Labor Day
Corsair is rolling out a Labor Day sales event that sees tempting discounts on some of its latest products. The RMx Shift desktop PC power supply enjoys its first price reduction, now available for $20 off MSRP for all variants, including 750W, 850W, 1000W, and 1200W, with code US-RMXPSU. That may not seem like a lot, but Corsair PSUs don't regularly go on sale, and the RMx Shift is its latest offering in the series, making this the first notable discount.
RMx Shift | $20 off with code US-RMXPSU at Corsair
The Shift is particularly interesting because it has a side-mounted connector interface, making it significantly easier to build. It's a fully modular design that lets you use just the cables you need, and it slots into all ATX cases without any issues. I used the 850W version of the Shift for a while now, and it has been terrific.
Read moreRead less
Corsair RMx Shift 850W (Image credit: Harish Jonnalagadda / Windows Central)
If you're looking to pick up a mini-ITX case, Corsair is rolling out a decent deal on the 2000D Airflow where it's bundling the case as well as an SF750 PSU for $30 off with code US-S750 on its official storefront. You'll need to add both products to the cart manually, and the deal is valid on both the standard and RGB versions of the 2000D case.
2000D Airflow & SF750 PSU bundle | $30 off with code US-S750 at Corsair
The case itself is pretty great, and it can accommodate 360mm coolers and full-size GPUs — including the likes of the RTX 4090 and RTX 4080 — without breaking a sweat.
Read moreRead less
iCUE LINK H100i AIO & QX120 fan bundle | $30 off at Corsair
And if you're in the market for cooling products, the iCUE Link H100i RGB cooler is also getting $30 off when bundled with a 3-pack of the QX120 fans, and it doesn't need a code — just add the bundle to the cart.
Read moreRead less
To round out the hardware deals, Corsair is offering a flat 15% discount on all of its DDR5 RAM products at the moment — just select the RAM module you want and use code US-DDR5 to get the deal.
Vengeance DDR5 RAM | 15% off with code US-DDR5 at Corsair
While Corsair sells a lot of products these days, the brand started out with memory products, and the DDR5-based Vengeance series continues to among the best RAM modules you can get for your gaming machine.
Read moreRead less
K95 RGB Platinum SE | $30 off at Corsair
There are a few deals on gaming accessories as well: the K95 RGB Platinum SE mechanical keyboard is down to $169, $30 off its usual selling price.
Read moreRead less
Scimitar Pro RGB | $20 off at Corsair
The Scimitar Pro MOBA mouse is also down to just $39, $20 off its launch price. All of these deals are valid through September 4, so if you are looking to pick up hardware components or need a new gaming keyboard, you should consider taking a look.
Read moreRead less
Harish Jonnalagadda
Senior Editor - Asia
Harish Jonnalagadda is a Senior Editor overseeing Asia for Android Central, Windows Central's sister site. When not reviewing phones, he's testing PC hardware, including video cards, motherboards, gaming accessories, and keyboards.
