Best PC parts and accessories under $100 as October Prime Day ends
Only spend $99 or less on these PC parts and accessory deals.
• Today's best deals
• Competitor deals
• Deals on PC parts
• PC accessory deals
• FAQ
Thanks to Amazon Prime Big Deal Days wrapping up tonight, Oct. 11 at 11:59 p.m. PT, several of the best PC game accessories and best PC parts are on sale right now for under $100. Of course, these sales are dependent upon availability and might sell out as we draw to the close of the event, so you'll need to act fast.
We're busy rounding up the very best early deals to choose from, which can include some of the best processors (CPUs) or the best graphics cards (GPUs), to help you save money on reliable and powerful tech. This means everything from controllers to headsets or even SSDs and processors. So check back here frequently to see what the latest PC part and accessory deals are for Amazon Prime Big Deal Days 2023.
Amazon Prime Day: Today's best deals
- Up to 41% off Sony TV and home theater
- Up to 57% off LG OLED TVs and sound bars
- Up to 45% off Samsung TVs and sound devices
- Up to 40% off eero mesh Wi-Fi router and systems
- Up to 44% off gaming laptops powered by NVIDIA
- Up to 50% off Amazon Fire tablets for the whole family
- Up to 39% off Tablets from Samsung, Google, and more
- Up to 42% off PCs and monitors from HP, Samsung, Acer, and more
- Up to 70% off Echo smart speakers and smart home bundles
- Up to 49% off Beats Studio Pro wireless noise-cancelling headphones
- Up to 40% off portable chargers
- Up to 48% off Micro SD cards
The best deals from competitors
- Newegg: Up to 40% off Graphics Cards
- Newegg: Up to 62% off SSDs
- Dell: Up to 30% off Alienware Laptops
- Dell: Up to 41% off Monitors
Amazon Prime Big Deal Days: Today's best PC part deals
WD Blue SN580 PCIe 4.0 1TB | was $49.99 now $39.99 at Amazon
It's almost frustrating how affordable solid-state drives have become when I remember how much cash I dropped on a 1TB drive WD Blue a decade ago. Those days are thankfully long gone, and this PCIe 4.0 M.2 drive from Western Digital is the modern equivalent with ultra-fast speeds.
✅Great for: Installing Windows 11 and using it as a boot drive, there will be plenty of space left over for modern games.
💰Price check: $39.99 at Best Buy
ASUS Prime B550-PLUS Motherboard | was $139.99 now $99.99 at Amazon
Packing the AMD AM4 Zen 3 Ryzen 5000 and 3rd Gen Ryzen ATX, this motherboard is a great budget option for your tower. It features a USB-A 3.2 Gen 2 port, four USB-A 3.2 Gen 1 ports, two USB-A 2.0 ports, a DisplayPort 1.2, an HDMI 2.1 port, an optical out port, and audio jacks to fit all your connection needs.
✅Pros: Affordable motherboard with HDMI 2.1 and DisplayPort 1.2
💰Price check: $121.99 at B&H
GIGABYTE GV-N1030D4-2GL GeForce GT 1030 Graphics Card | was $109.99 now $60.99 at Amazon
This simple graphics card from GIGABYTE utilizes an NVIDIA GeForce GT 1030 GPU and features 2GB DDR4 64bit memory within a small 150mm design. This compact shape makes it easier to install than some other, more unwieldy graphics cards.
✅Pros: Great for normal desktop usage and some simple gaming
💰Price check: $96.99 at Newegg
TP-Link WiFi 6E Card AXE5400 | was $79.99 now $54.99 at Amazon
You can upgrade your rig with low latency Wi-Fi 6E via this AXE5400 Wi-Fi card and included antenna base. TP-Link is a known and trusted tech company that specializes and Wi-Fi devices and as such, this product works efficiently with Windows 10 and Windows 11.
✅Pros: Easy installation, antenna has a magnetized base, supports Bluetooth 5.3
MSI B550 Gaming GEN3 AM4 motherboard | was $119.99 now $99.99 at Amazon
This couldn't be an easier recommendation for me (Ben, Tech Editor) since it's the exact motherboard from my personal machine, and I've used this thing almost every single day without fault. I chose it to pair with a Ryzen 5 2600 (which I'm about to replace with a Ryzen 7 5800X, also on sale at Amazon,) and it's never caused any issues.
It's compatible with AMD processors using the AM4 socket, so there are plenty of budget-friendly options to choose from. There aren't any 3-pin ARGB headers, but there are 4-pin JRGB alternatives, so consider your options for aesthetics. Nevertheless, I still use an RGB CPU cooler and RGB RAM alongside case fans with their own lighting, so it's not an issue.
✅Great for: Budget-friendly custom gaming PC builds using AMD Ryzen processors.
💰Price check: $119.99 at Newegg
Corsair VENGEANCE RGB PRO DDR4 32GB (2x 16GB) 3600MHz CL18 | was $134.99 now $75.99 at Amazon
The best thing about technology advancing to a new generation is that all the expensive stuff from the last comes crashing down in price, but the performance is often still fantastic. DDR4 vs DDR5 is more of an issue when choosing your processor since some of the most cutting-edge CPUs will only support the latter, but plenty of AMD and Intel chips still work with the far more affordable DDR4.
For RGB enthusiasts, this world-class Corsair Vengeance kit comes with 2x 16GB modules of DDR4-3600 with CL18 timing and customizable lighting to boot. It doesn't actually make your computer any faster, but 32GB of RAM clocked at 3600MHz is more than enough for anyone building a custom machine with DDR4 memory and an appropriate CPU.
✅Great for: Pairing with previous-gen AMD CPUs and modern Intel CPUs (up to 13th Gen.)
💰Price check: $79.99 at Newegg
MUSETEX E-ATX PC case | was $179.99 now $89.99 at Amazon
Working on building a brand-new rig? You've got to have a good computer case and this one is perfect for anyone who likes to see what's inside since its side panels feature tempered glass. It comes with four RGB fans pre-installed as well as seven expansion slots.
✅Pros: Pre-installed RGB fans, glass panels, seven expansion slots, fits up to 390mm GPU
Amazon Prime Big Deal Days: Today's best PC accessory deals
Logitech Blue Yeti Microphone: was $99.99 now $75.49 at Amazon
This Blue Yeti Nano USB microphone is a very popular choice for streaming, playing online multiplayers with friends, podcasting, or otherwise recording yourself. That's because it offers great performance at a lower price point, so you can rely on it for a variety of purposes.
✅Pros: Great streaming and recording performance at a lower price point
💰Price check: $79.99 at Best Buy
Logitech Blue Yeti Professional Microphone: was $129.99 now $85.48 at Amazon
The Blue Yeti Professional serves as a step up from the smaller Yeti Nano and is a great choice for people who want an even better microphone for their PC needs. Simply plug the USB cable into your computer or laptop and you'll be ready to go.
✅Pros: Great for recording or streaming
💰Price check: $89.99 at Best Buy
Divoom Ditoo Retro Pixel Art Game Bluetooth Speaker: was $129.99 now $79.92 at Amazon
Many people love to use this as a customizable decoration for their desktop area. The little screen and simple controls allow you to create pixel art or even a clock. Plus, it offers a 10W Bluetooth speaker, which can allow images on the screen to respond to the sound it produces for a fun effect.
✅Pros: Cute and customizable, 10W Bluetooth speaker
Samsung EVO Select 256GB microSDXC: was $24.67 now $16.99 at Amazon
Samsung had a legitimate reason to make its microSD cards the best they could be when producing hundreds of smartphones and tablets designed to use them.
Available in 64GB, 128GB, 256GB, or 512GB, all models are discounted for October Prime Day. The middle ground of 256GB is the sweet spot for most use cases, including a strong recommendation as the best SD card for Steam Deck and other PC gaming handhelds.
✅Great for: Backing up games and installing extra software on the best gaming handhelds.
💰Price check: $19.99 at Best Buy (EVO Plus is the non-Amazon variant.)
PNY PRO Elite Class 10 U3 V30 microSD 1TB | was $124.99 now $79.99 at Amazon
microSD card slots may not be as common in smartphones anymore, but they're still widely used for compact storage of media, such as videos, movies, music, and photos. A microSD card of this caliber is more than fast enough for cameras, too, supporting 4K UHD recording.
✅Great for: Media storage, video recording and photography
Soundcore Anker Space Q45 Headphones: was $149.99 now $99 at Amazon
These Anker Soundcore headphones not only look sleek and feel comfortable but also provide active noise canceling for a better listening experience. Wear them while jamming out to your favorite music or playing solo-player games on your computer.
✅Great for: Active noise canceling, 50-hour battery life, Bluetooth 5.3
💰Price check: Best Buy $99.99
TP-Link AX1500 WiFi 6 Extender | was $89.99 now $54.99 at Amazon
Once installed in your home or office, this device helps boost Wi-Fi coverage up to 1,500 square feet while supporting as many as 25 devices. The companion app makes it easy to interact with and it provides a Gigabit Ethernet port for a faster, wired connection for your laptop or computer.
✅Pros: 1.5 Gbps, built-in Ethernet port, boosts coverage up to 1,500 Sq.ft.
Xbox Core Wireless Controller | was $59.99 now $49.00 at Amazon
Usually, these beautiful Xbox controllers are rather expensive, but this current discount makes them more affordable. It's compatible with Xbox Series X|S, Xbox One, and Windows PCs via Bluetooth.
Similar deal: $49.99 at Best Buy
✅Pros: 40-hour battery life
Big Deal Days: Frequently asked questions
The specifics for Amazon Prime Big Deal Days are now publicly available, with minor hints as to which brands and categories will enjoy significant discounts. Rest assured, we'll update this page with the latest dates and details whenever the company releases more information.
Amazon Prime Big Deal Days starts at 3 AM ET on Tuesday, October 10, and will run through October 11. If you have any Alexa-compatible hardware, you can say, "Alexa, set a reminder for Prime Big Deal Days" to have Amazon create a reminder for the event.
Which countries are taking part in Big Deal Days?
Australia, Austria, Belgium, Brazil, Canada, China, France, Germany, Italy, Japan, Luxembourg, Netherlands, Poland, Portugal, Singapore, Spain, Sweden, the US, and the UK will all take part in Prime Big Deal Days via their respective storefronts. If your country doesn't have its own localized version of Amazon, you may still be able to make purchases from a neighboring variant, but usual restrictions likely apply, so check your local Amazon international shipping terms and conditions.
Do I need an Amazon Prime membership?
Yes. Prime Big Deal Days is a member-exclusive sales event just like Prime Day before it and Prime Early Access Sale before that. If you're not already a member, you'll need to sign up for Amazon Prime for $14.99 per month or $139 annually (plus tax) to qualify for discounts. For new users, a 30-day trial of Prime is the perfect way to take advantage since you're free to cancel your subscription after the event.
Amazon Prime: Free 30-day trial
Enjoy all the benefits of exclusive discounts during Amazon events, and cancel anytime. If you decide to stay, it's $14.99/month (plus tax) after the trial. Includes extra benefits like free games via Prime Gaming and more bonus content for subscribers.
Self-professed gaming geek Rebecca Spear is one of Windows Central's editors and reviewers with a focus on gaming handhelds, mini PCs, PC gaming, and laptops. When she isn't checking out the latest games on Xbox Game Pass, PC, ROG Ally, or Steam Deck; she can be found digital drawing with a Wacom tablet. She's written thousands of articles with everything from editorials, reviews, previews, features, previews, and hardware reviews over the last few years. If you need information about anything gaming-related, her articles can help you out. She also loves testing game accessories and any new tech on the market. You can follow her @rrspear on X (formerly Twitter).
- Ben WilsonSenior Editor
