How to use any TV remote with an Xbox Series X|S using HDMI-CEC
TV remote with Xbox backdrop
There are a range of Xbox TV media remotes you can buy to attach to your Xbox One, Xbox Series X, or Xbox Series S console, but if you have a relatively new TV, you might not need to.
Thanks to the magic of HDMI-CEC, you may be able to ditch having multiple remotes entirely, and just use whatever remote came with your TV to control your Xbox. HDMI-CEC is a relatively new tech that stands for "Consumer Electronics Control," and it allows devices to communicate over HDMI for adjusting TV controls, interacting with apps, and so on. For Xbox, it allows you to control the entire dashboard, as well as use media controls in apps like YouTube and the Blu-ray player.
It's often not enabled by default, however, and the steps to enable it may vary by manufacturer. But here are the basic steps for enabling it for your Xbox Series X or Xbox Series S.
Recent updates
UPDATE (October 23, 2024): We've received reports that this feature hasn't actually reached general availability yet. We've reached out to Microsoft and Xbox to double check if / when it will go live beyond the Xbox Insider Program. It might have slipped through the cracks. Stay tuned.
Enable HDMI-CEC on your TV
Many TVs don't have HDMI-CEC enabled by default. (Image credit: Windows Central)
1. First, you'll need to enable HDMI-CEC on your TV or monitor, which often isn't turned on by default. Different manufacturers may even have different brand names for HDMI-CEC. Here's what it looks like on a Samsung TV.
2. Press the home button on your TV remote, or the settings button if one is available.
3. You're looking for a setting that refers to HDMI-CEC or external device control. On a Samsung TV, it's under General > External Device Manager > Anynet+. I have no idea why Samsung branded it this way, but here we are.
4. Once you have enabled HDMI-CEC features on your TV, you should be able to enable remote control on your Xbox console.
It's worth checking with the manufacturer of your TV or display to make sure it has HDMI-CEC, although most of the best modern 2022 TVs for Xbox most likely do have HDMI-CEC. LG TVs refer to it as "SimpLink," Philips describes it as "EasyLink," Samsung calls it "Anynet+," Sony TVs often call it "BraviaLink," or "BraviaSync," and so on.
Enable HDMI-CEC on your Xbox
Next, you need to enable HDMI-CEC on your Xbox console. Doing this is relatively straightforward, but the setting is hidden away in a few menus. Here's how to get it done.
1. As depicted above, open the Xbox menu using the Xbox button on your controller.
2. Navigate right until you find Settings.
3. Navigate down to Devices & connections.
4. Select Remote features as seen above.
5. If it's not already enabled, in this new menu select Enable remote features. You may need to input your passkey if you have one set up. You may also be prompted to turn off power-saving settings you may have set up.
6. Next, select TV & A/V power options in the same menu.
7. Enable HDMI-CEC on the left column.
8. Select Use TV remote for console on the right column, and configure any other settings you'd like to set.
Note: If you set up the console to turn off and on other devices, it may take control of your TV's power at unwanted moments if you use your TV for things other than gaming. Also, you may need to reboot your TV and Xbox by long-pressing the power button on your console and TV remote to make sure the new settings stick.
If you don't have a TV with HDMI-CEC and still want a dedicated remote for controlling your TV, we typically recommend the Talon Media Remote for Xbox as our top recommendation for best Xbox media remote
TOPICS
CATEGORIES
Jez Corden
Executive Editor
Read more
An LG TV with the text "This is an Xbox (coming soon to LG Gaming Portal)"
Xbox and LG team up, LG TVs will also be Xbox later this year
New Xbox Series X|S models shown at the 2024 Xbox Showcase.
Xbox announces new repair options for Xbox consoles, including first officially authorized third-party repair stores
Xbox Series X controller in front of LG C2 OLED evo TV.
Best Xbox controllers in 2025: Razer, GameSir, and more — Who comes out on top?
JSAUX 6-in-1 Multifunctional Docking Station connected to TV.
I play ROG Ally handhelds connected to my TV like a console, and it's easy to set up
Xbox Game Bar compact mode on the ROG Ally
How to access and use Xbox Game Bar on the ROG Ally
Best Xbox Headsets 2025 logo, with a Turtle Beach Stealth 700 (Gen 3) photograph on a home office background
Best Xbox headsets in 2025: I've spent 10 years reviewing headsets, and these are the ones you should buy
Latest in Xbox
The Thing: Remastered key art
The Thing comes to Xbox Cloud Gaming's "Stream Your Own Game" library alongside other new arrivals
Cover art for Heroes of the Storm.
Xbox Game Pass will give you more benefits in free-to-play games like Heroes of the Storm
Call of Duty: Black Ops 6 accessibility settings at launch.
Activision user research workers form union under Microsoft
Xbox Game Hubs 2025
A quick look at Xbox's new "Game Hubs," a small new feature that may be more meaningful than you think
8BitDo Retro 87 Mechanical Keyboard Xbox Edition
Drop everything — the Xbox keyboard is on sale
Xbox
Microsoft's Xbox strategy has reader opinions split almost perfectly in half
Latest in How-to
Atomfall
Can I play Atomfall on Steam Deck, ROG Ally, and other gaming handhelds?
Windows 11 answer file
How to easily create an unattended answer file for Windows 11
The First Berserker: Khazan
Is The First Berserker: Khazan on Xbox Game Pass?
Clair Obscur: Expedition 33
Is Clair Obscur: Expedition 33 on Xbox Game Pass?
A close-up of Hazel in South of Midnight
Is South of Midnight on Xbox Game Pass?
Atomfall screenshot
Atomfall: How to grab the best melee weapon and melee perk right away
