Starfield PC specs: Recommended, Minimum, and Ultra system requirements
Starfield Review
Team Windows Central has been blessed with the opportunity to play Starfield ahead of its release, and we've been absolutely blown away by the title's incredible scope and depth. As we said in our Starfield review, it's "a thought-provoking, daunting, and landmark experience," and undoubtedly "one of Microsoft's best exclusive games in over a decade."
Indeed, Starfield seems almost unfathomable, and if you're a PC gamer, you're probably wondering about the hardware you'll need to enjoy it all smoothly. Thankfully, Bethesda has shared Starfield's full PC system requirements, and we've got all that information for you right here.
Here's everything you need to know about these requirements, including what the minimum and recommended specs are and how you can check to see if your rig will be able to support your star-sailing adventures.
Starfield PC specs: System requirements
Starfield: Spaceship flying near a planet. (Image credit: Bethesda Softworks)
Now that Bethesda has officially shared Starfield's requirements, we've learned precisely what hardware you'll have to have in order to play the game. Notably, these specs include the processor, memory, graphics card, and storage hardware you'll need, as well as the operating system and DirectX version the game requires.
Overall, Starfield's requirements are very reasonable for a AAA 2023 release, especially when you consider just how big it is in terms of scale. With that said, it's notable that 16GB of RAM is required, as is having an SSD (time to finally join the SSD gang, HDD users). Also, the game's large 139.84GB file size may force you to uninstall some games or add extra storage to your system.
Below, you'll find a complete list of Starfield's minimum and recommended specs, along with some predictions for the hardware you'll need for Ultra gameplay.
Starfield PC Minimum system requirements
With this hardware, you'll likely be able to play Starfield at 720p or 1080p with a solid frame rate of 30 FPS on Low settings.
  • OS: Windows 10 version 22H2 (10.0.19045)
  • Processor: AMD Ryzen 5 2600X, Intel Core i7-6800K
  • Memory: 16 GB RAM
  • Graphics: AMD Radeon RX 5700, NVIDIA GeForce 1070 Ti
  • DirectX: Version 12
  • Network: Broadband Internet connection
  • Storage: 125 GB available space
  • Additional Notes: SSD Required
In most cases, recommended specs will enable you to turn settings up to Medium or High and enjoy a decently high framerate while playing at 1080p or 1440p. The best gaming laptops should be able to handle this rather easily.
  • OS: Windows 10/11 with updates
  • Processor: AMD Ryzen 5 3600X, Intel i5-10600K
  • Memory: 16 GB RAM
  • Graphics: AMD Radeon RX 6800 XT, NVIDIA GeForce RTX 2080
Starfield PC Ultra Requirements
While Bethesda hasn't given its own recommendations for specs that'll allow you to have a stellar experience at Ultra settings and at 4K resolution, AMD has made some suggestions for CPU and GPU hardware. These include the following:
  • CPU: AMD Ryzen 7 7800X3D
  • GPU: AMD Radeon RX 7900 XT
You'd want to pair these specs with a good AM5 motherboard like an AMD X670, along with 32GB of DDR5 RAM. If you prefer Intel-based systems, you'll want to aim for something like the Core i9-12900K or the Core i7-13700K and a quality LGA1700 motherboard. If you'd prefer an alternative GPU, NVIDIA's high-end RTX 30 Series cards and newer 40 Series cards will give you all the performance you'll need.
Can my PC run Starfield?
Starfield player with creature. (Image credit: Windows Central)
Not sure if your current PC meets the requirements listed above? Fear not, as there's an easy way to check. All you need to do is perform a quick analysis with the DirectX Diagnostic Tool, a built-in piece of Windows software that allows you to identify all your components in seconds. Here's how to use it.
1. Click the Windows button on your taskbar.
2. Type dxdiag.
3. Click dxdiag in the search results. Windows will then show your PC specifications.
4. Navigate to the System tab for details on your processor, memory, and Windows version.
5. Navigate to Display tab for details on your graphics card hardware.
Note that checking your available hard drive space is even easier. All you have to do is open File Explorer, look for the drive you're planning to install the game on, and check to see that you have over 125 GB of free space.
How to upgrade my computer's GPU to play Starfield
Starfield is an incredible game with impressive graphics and a vast universe to explore. If you're looking to update your computer in order to play this sci-fi adventure better then you should check out our guide on how to upgrade your PC's graphics card.
Into the stars
With so many exciting possibilities made available to Starfield players, it's understandable that many people will want to get the most out of the game by making sure their computers can meet certain requirements. While it's perfectly fine to play a game at the minimum specs, the experience will be a whole lot smoother and more convenient if your gaming laptop or computer has a bit more oomph to it. This means having a powerful GPU and plenty of storage to make room for the game.
Whether you're looking into purchasing a new computer or laptop that can handle Starfield or you're trying to find out what processors you need to use in your existing rig, we at Windows Central wish you the very best of luck in your preparations.
Starfield is finally here, and it's undoubtedly one of the best Xbox games and best PC games for lovers of space exploration, deep RPG gameplay, and the sci-fi genre as a whole.
Starfield Standard Edition
The Standard Edition of Starfield costs $70, and only includes the base game. Note that if desired, you can upgrade the game with the Premium Edition Upgrade later.
Buy at: Xbox | Steam (GMG) | Amazon (Xbox) | Best Buy (Xbox) | GameStop (Xbox) | Walmart (Xbox) | Walmart (PC) | GAME (UK, Xbox)
Starfield Premium Edition
The Premium Edition of Starfield includes bonuses alongside the main game, and you're guaranteed access to the first story expansion when it arrives. You can also start exploring vast planets five days early.
Buy at: Xbox | Amazon | Steam (GMG)
TOPICS
CATEGORIES
Brendan Lowry
With contributions from
Read more
DOOM: The Dark Ages cannon
DOOM: The Dark Ages PC requirements and specs — Can your computer run id Software's latest shooter?
Kingdom Come: Deliverance 2
Kingdom Come: Deliverance 2 PC system requirements and specs — Can you run this grand medieval RPG?
Assassin's Creed Shadows protagonists.
Assassin's Creed Shadows PC system requirements: Does my computer meet minimum or recommended specs?
Sid Meier's Civilization VII promotional screenshot
Sid Meier's Civilization VII PC requirements and specs: Can you run this grand strategy sequel?
Screenshot of South of Midnight.
South of Midnight PC requirements and specs — Is your computer ready for this Southern folktale adventure?
Microsoft Flight Simulator 2024 promo logo
Love Flight Simulator? These pre-built PCs can deliver a high-end experience.
Latest in Gaming
Screenshot of one of the new flat world presets in Minecraft.
Minecraft testing new flat world presets and a better way to locate your friends in-game
Cover art for Heroes of the Storm.
Xbox Game Pass will give you more benefits in free-to-play games like Heroes of the Storm
The First Berserker: Khazan
Is The First Berserker: Khazan on Xbox Game Pass?
Lies of P boss
Grab these must-play games at killer deal prices during the CDKeys Spring Festival
Alienware Area-51 laptops (2025)
Dell revives Alienware Area-51 with powerful new gaming PCs
The First Berserker: Khazan review and Metacritic score roundup — this stylish Soulslike sounds like a must-play action RPG
Latest in How-to
Clair Obscur: Expedition 33
Is Clair Obscur: Expedition 33 on Xbox Game Pass?
A close-up of Hazel in South of Midnight
Is South of Midnight on Xbox Game Pass?
Atomfall screenshot
Atomfall: How to grab the best melee weapon and melee perk right away
Atomfall District B
Atomfall: How to open District B, get inside the Robot Facility, and grab the Signal Redirector
Atomfall District A photo
Atomfall: How to open District A and get inside the Medical Facility
