Best Legion Go power banks 2025: Charge and play your handheld with a battery pack
Grab a battery pack that provides enough power so you can keep playing your Legion Go.
The Lenovo Legion Go is one of the most powerful gaming handhelds we've seen so far, with its gorgeous 8.8-inch IPS touchscreen that supports up to 144Hz and the AMD Ryzen Z1 Extreme processor.
However, the battery drains quickly and it needs at least 65W power delivered to charge up the handheld while you play.
Here are the best Legion Go power banks you can get right now.
UPDATE May 9, 2025: I checked each of the links to make sure they go to the proper, in-stock product. I also added an FAQ section at the bottom of the page.
Anker is known as the best power bank manufacturer on the market, so it's no surprise that our number one pick for the Legion Go is the Anker 747 Power Bank. It offers 87W max output with a high 25,600mAH capacity to keep the Legion Go juiced up as you play. There are two USB-C ports and two USB-A ports. Plus, it comes with its own wall charger to more easily charge itself back up after use.
This 100W power bank is one of the best value options, providing a decent charge for the Legion Go. It offers two USB-C ports and a USB-A port. Meanwhile, the battery has a 25,000mAh capacity, which should supply multiple charges to the gaming handheld. On top of that it even has a screen to help you know how much battery life is left. Its larger capacity, higher output, screen, and lower price make it a great value.
With its built-in USB-C cable, this Anker Power Bank makes it so you don't have to keep track of these wired connections. The high 87W output is perfect for the Legion Go, and since it has a 20,000mAh capacity, it can last for multiple charges. Plus, a small screen near the USB-A and USB-C ports lets you quickly know how much juice is left in the power bank. It's available in black, blue, or white.
Regarding the Legion Go, it's a good idea to get a battery pack with a higher wattage, and the 100W Baseus Blade is perfect for that. It offers a 20,000mAh capacity in a very slim form factor that can easily fit into backpacks and other bags during travel. It features a convenient screen to let you know the battery pack's current remaining battery level, charging power, and charging/recharging time.
This is a perfect all-rounder or survival power bank well-suited to charging the Legion Go. Output-wise, there's a USB-A port, a USB-C port, and even a 100W AC outlet, so you can plug in the Legion Go charging adapter. Since there's also an LED flashlight, it provides additional usefulness in the dark when traveling. Just make sure to keep the back end clear while in use, so the internal fan can keep this device cool.
This 100W USB-C PD port and USB-A 15W port allow this high-capacity 30,000mAh power bank to really be useful to the Legion Go. Rectangular and relatively compact, it's easy to travel with and is better priced than other options at this capacity and wattage. You can easily track how much battery is left with the four LEDs that indicate when the device has roughly 25%, 50%, 75%, or 100% battery life.
Provide power and keep playing Legion Go
As you can see from my Legion Go review, Lenovo's gaming handheld is one of the most powerful on-the-go PC gaming devices to be released thus far.
This is partly thanks to the impressive AMD Ryzen Z1 Extreme processor that it utilizes, combined with the gorgeous and large 8.8-inch IPS touchscreen, which provides up to a 144Hz refresh rate.
- Legion Go vs ROG Ally
- Legion Go vs Steam Deck
- What is the Legion Go?
- Best Legion Go S accessories
- Legion Go S review
But these same features make it so that the handheld runs out of battery life faster.
Much like the ASUS ROG Ally, the Legion Go requires a power bank with at least a 65W (or higher) output to recharge while you play in Turbo mode.
Really, one of the most essential and best Legion Go accessories is a reliable battery pack that offers enough wattage to juice the gaming handheld back up while you play.
Above all, I recommend grabbing the Anker 747 Power Bank since it's made by a reliable company, offers 87W output, and has a large 25,600mAh capacity. It even comes with a USB-C cable and an outlet adapter.
If you want something less expensive that is still an amazing value I suggest going with the 100W, 25,000mAh INIU Power Bank. It even has a screen to help you check battery life.
What makes Lenovo Legion Go standout from other handhelds?
In addition to being a commanding device in the handheld gaming space, Lenovo has also worked to provide innovative new features to this system.
This includes having removable controllers (similar to what we've seen on the Nintendo Switch). You can even use accessories like the one seen in my JSAUX Grip Connector review to unite the two halves into a more traditional controller.
Plus, the right controller features a trackpad (like the Steam Deck), a mouse wheel, right and left click buttons, and an FPS switch that allows people to use this controller more like a mouse when detached.
This makes the Legion Go more useful when players interact with specific menus or mouse-centric in-game mechanics like aiming or moving the camera.
The Legion Go conveniently comes with its own carrying case and a base for the right controller's FPS mode, so you don't have to purchase these things separately.
Legion Go power bank FAQ
What should I look for in a power bank for Lenovo Legion Go gaming handhelds?
When choosing a power bank for your Legion Go, you'll need to consider power delivery, capacity, and ports.
Power delivery or output, is the most important factor to consider. The Legion Go is a powerful device, so if you want to continue to play the handheld while it charges back up, you'll need to get a 65W power bank or higher.
The larger the capacity of the battery pack, the more juice you can feed to your handheld, thus allowing you to play longer before needing to recharge the power bank. Getting one that is 20,000mAh or higher is ideal.
As far as ports go, you get to determine how many you actually want. Some power banks are minimal while others offer plenty of connection areas so you can charge multiple devices at once.
What power bank output do I need for Legion Go?
You'll need to get a power bank that is 65W or higher in order to keep up with the power consumption needs of Legion Go handhelds.
What are the best power bank brands?
There are several trusted power bank brands on the market, but the ones I recommend most are Anker and Baseus. Both companies offer a good range of options for various devices.
Self-professed gaming geek Rebecca Spear is one of Windows Central's editors and reviewers with a focus on gaming handhelds, mini PCs, PC gaming, and laptops. When she isn't checking out the latest games on Xbox Game Pass, PC, ROG Ally, or Steam Deck; she can be found digital drawing with a Wacom tablet. She's written thousands of articles with everything from editorials, reviews, previews, features, previews, and hardware reviews over the last few years. If you need information about anything gaming-related, her articles can help you out. She also loves testing game accessories and any new tech on the market. You can follow her @rrspear on X (formerly Twitter).
