Save now and later with $40 off the Flume smart home water monitoring system
The Flume smart home Wi-Fi water monitoring system is down to $159 on Amazon. The system normally sells for $199 but is down to $159 for Prime Day. It has never directly gone on sale before, either, so you're looking at an exclusive deal.
$169.00 $199.00 Save $30
$169.15 $199.00 Save $30
The Flume has intelligent leak detection that can help you protect your home from water damage. It will monitor the water usage across your home, including outside sprinklers. Then it uses that data to catch costly leaks, find out where your water is going, and help you take action to conserve it. It's also easy to install and the wireless signal works up to 1,000 feet. Use the Flume app to get real-time leak detection and special notifications.
