Display your favorite headphones with Corsair's Premium stand while it's on sale for its lowest price ever
The Corsair ST100 RGB Surround Sound premium headset stand is down to $47.99 on Amazon. That price is $12 off its regular street price and the best we have ever seen. This stand does not drop in price very often.
Corsair K95 Platinum Cherry MX Speed RGB mechanical keyboard
$119.99 $200.00 Save $80
Full-size keyboard with Cherry MX Speed mechanical switches. Includes six one-touch keys you can program to do anything you want. Create custom macros with the 18 programmable G Keys. Includes a USB passthrough port and a palm rest.
Corsair K95 RGB Platinum XT mechanical gaming keyboard
$159.99 $200.00 Save $40
Not for the faint of heart. This thing uses Cherry MX Speed XT Silver switches. Has full RGB on individually backlit keys with a 19-zone LightEdge on the top. Has precision-molded keycaps, six programmable macro keys, and a leatherette palm rest.
Corsair K95 RGB Platinum mechanical gaming keyboard gunmetal
$109.99 $160.00 Save $50
Full keyboard with six one-touch hot keys for instant access to internet, email, volume controls, and more. Uses Cherry MX Speed mechanical switches. Has 18 programmable G keys and USB passthrough ports. Comes with palm rest, too.
Corsair K57 RGB wireless gaming keyboard
$79.99 $90.00 Save $10
Includes Corsair's Slipstream wireless for sub-1ms low-latency Bluetooth. Also go USB wired. Get per-key RGB backlighting and six programmable macro keys. Includes a detachable soft rubber palm rest and dedicated volume and multimedia controls.
Corsair iCue Commander Pro smart controller for RGB lighting and fan speed
$58.82 $75.00 Save $16
Turn any PC case into a smart case and use Corsair's iCue software to control up to six case fans and two RGB lighting channels. Two USB 2.0 internal headers let you connect internal USB devices. Monitor temperatures and your whole system.
Corsair doesn't mess around with headsets. It ain't just a place to rest your headphones when you're done. But let's start with the stand. It's made with a durable aluminum and uses an iconic display that helps show off your favorite headset. The bottom has dynamic RGB lighting with nine zones for unlimited color options. The side has a 3.5mm audio input that allows you to enable a full range Stereo or 7.1 Surround Sound multi-channel audio experience. There are also two USB 3.1 inputs to provide charging power and fast speeds for your headset, phone, and other devices. You can even use Corsair's iCue software to customize the lights and adjust the audio equalizer settings.
