Converting your Nokia wireless charger into a car charger
If you've been wondering if the Nokia wireless charging pad would make for a good car charger, take a gander at the above video. MakeIt Diy is offering a "do it yourself" guide to converting a charging pad into a car charger/cradle.
The charging pad is held into place with a Garmin Nuvi vent mount and hard wired into the car's fuse box using a "add-a-fuse" attachment that can be picked up at most automotive stores. You'll need to glue a mounting plate to the back of the charging pad to mount it to he vent mount.
To better hold the Windows Phone in place, neodymium magnets are taped to the charging pad and inside the skin case on the Nokia Lumia 920. It's not a bad solution to hold you over until Nokia releases a wireless charging cradle for the car.
Source: MakeIt Diy/YouTube, Thanks, AK, for the tip!
George is the Reviews Editor at Windows Central, concentrating on Windows 10 PC and Mobile apps. He's been a supporter of the platform since the days of Windows CE and uses his current Windows 10 Mobile phone daily to keep up with life and enjoy a game during down time.
