Best USB-C adapters and hubs for Surface Pro 8 and Surface Pro 9 in 2025
The Surface Pro 8 and Surface Pro 9 are brilliant 2-in-1 Windows laptops, but due to their form factor, they aren't exactly packed with ports. Fortunately, both devices support USB-C and Thunderbolt 4, which means you can easily expand your port options with a USB-C hub or an adapter. If you don't have a Surface Pro, the great thing about our selection of hubs is that all of them will work with all your favorite USB-C-enabled laptops and tablets, including other Surface devices like the Surface Laptop Studio. Here are the best USB-C adapters and hubs for Surface Pro 8 and Surface Pro 9.
The bottom line
Thanks to having a USB-C port, the Surface Pro 8 can be easily expanded to offer a number of additional features. Whether you want to add additional ports, external displays, or memory card readers, there's a compatible dock or adapter that will do the job.
The CalDigit SOHO dock is the best of the bunch, covering off all the main connectors you might want to attach to your Surface Pro 8. It is a tad pricey, but that's OK because there are some great budget alternatives.
USB-C can also be used alongside the Surface Connect port, so if you already have an existing Surface Dock, you can pair it alongside a USB-C hub for maximum connectivity.
If you're at your desk and want to minimize clutter, you can connect your Microsoft tablet to a USB-C monitor. Many of these displays come with a built-in hub on the rear where you'll be able to connect additional peripherals. This way, you'll have just one cable running from the Surface Pro 8 to the monitor.
Zac Bowden
Senior Editor
Zac Bowden is a Senior Editor at Windows Central. Bringing you exclusive coverage into the world of Windows on PCs, tablets, phones, and more. Also an avid collector of rare Microsoft prototype devices! Keep in touch on Twitter and Threads
Read more
Surface USB4 Dock
Microsoft unveils new 'Surface USB4 Dock' that's smaller and $100 cheaper
The Razer USB4 Dock held in the hand and showing its rear ports.
Razer USB4 Dock review: The best value Thunderbolt dock without Thunderbolt
9 essential apps if you own a Surface Pen
You don't need to overspend on an official Surface Pen; check out the best alternatives for your Surface PC
Image of the Dell UltraSharp 27 4K Thunderbolt Hub Monitor (U2725QE).
Turns out I really value having an entire Thunderbolt 4 hub built into my monitor
Surface Logo
Surface PCs are great for students, but which one should you choose?
Microsoft Surface Pro 11 with Qualcomm Snapdragon X Elite
The best Surface Pro 11 with Snapdragon deal is still almost half the price of the new Surface Pro 11 with Intel
Latest in Surface Pro
Surface Pro 11 with Snapdragon deal snags you a free keyboard just in time for back to school
A common internet meme depicting a man looking at the Surface Pro 11 with a stack of other PCs in the background.
I've got 18 laptops in my office, and I'm still tempted by the Surface Pro 11 with OLED and Snapdragon X
Microsoft Copilot event May 20 2024
Sadly, you'll have to wait a while longer for a 5G Surface Pro 11
Surface Pro 9
Microsoft's Surface Pro 9 is 'excellent in almost every way,' and it's now down to the lowest price I've ever seen
Surface Pro 9
Surface Pro 9, 'the best bit of hardware Microsoft has ever released,' is now under $1,000 with a keyboard
Christmas deal header for Microsoft Surface Pro 9
Surface Pro 9 deal — SAVE $300 buying one of the best 2-in-1 laptops at Best Buy
Latest in Buying-guide
MSI Claw 8 AI+ flat on a table with a Steam Deck below it.
I tested MSI Claw 8 AI+ and compared it against Steam Deck — Here's why one of these handhelds reigns supreme
MSI Claw 8 AI+ propped up next to an ROG Ally X on a table.
I reviewed MSI Claw 8 AI+ and ROG Ally X — Here's which PC gaming handheld you should actually get
NVIDIA RTX 5070 vs. RTX 5070 Ti
Is NVIDIA's RTX 5070 right for you? Why it might make sense to spend more on the RTX 5070 Ti.
AMD RX 9000
Is it worth spending more on the RX 9070 XT? — What you need to know before buying an AMD RDNA 4 GPU
AMD Radeon RX 9000
AMD's RX 9000 GPUs are selling out everywhere, but I found these in-stock pre-built PCs
NVIDIA CES 2025
The RTX 5070 Ti is sold out, but I found 7 pre-built PCs still available now
