Best Magnetic Parts Trays for PC Building
If you're building or customizing your PC rig, there may be a time when you need a place to store screws. It's okay to use a small plastic bag or bowl, but even then you may lose a vital piece of the puzzle. A handy solution for PC builders is a magnetic parts tray, which holds all your much-needed parts in one place. Titan Tools' magnetic bowl is a great option that doesn't cost much, but there are a few more that might be of interest.
Calossal companion
This stainless steel dish from Titan Tools is exactly what every PC builder needs. You'll be able to throw all your screws and other micro-parts into the dish and never lose them again, even if you somehow manage to knock it over. The price here is for the smallest size, but other shapes and sizes are available should you work with more than one machine.
A magnetic tray is an affordable tool you must add to your PC building arsenal and this example from Titan Tools is just $5 — perfect for holding all your screws and small parts.
