Watch HD broadcasts up to 60 miles away using the ClearStream 2MAX TV antenna on sale for $70
The Antennas Direct ClearStream 2MAX indoor/outdoor HDTV antenna is down to $69.99 through Best Buy's official eBay storefront and the main site. The next best price on this antenna is $74 at Walmart, but it sells as high as $80 or more at other retailers including Amazon.
The doubly strong 4MAX antenna is also on sale right now. You can find it as low as $113.50 at Walmart. Best Buy's sale through eBay and the main site is selling it for $129.99.
Read Cordcutter's review of the 2MAX antenna to learn more about it. Use one of these HDTV antennas to get over-the-air HD broadcasting and watch some of your favorite channels even without a cable subscription. The 2MAX can receive signals from up to 60 miles away. Plus, because it's weather resistant you can mount it indoors or outdoors. You shouldn't have to adjust it much either because the multi-directional design helps it work no matter which way it's placed. Use a reception map to see how well the antennas will work where you live.
