Save money before your next workout with Anker's Soundcore Neo true wireless earbuds down to $41
The Anker Soundcore Liberty Neo noise-cancelling sweat-resistant true wireless earbuds is down to $40.99 with a $9 off on-page coupon on Amazon. The earbuds almost always sell for around $50, and we have never seen a direct price drop lower than that until today.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The earbuds have expertly-tuned graphene drivers that provide a wider soundstage for your music, accuracy, and clarity. They also have Bass Up technology for more powerful low frequencies. The earbuds also combine an LDS antenna and Bluetooth 5.0 technology for a solid, unbreakable link between your earbuds and your streaming device. The battery lasts up to 3.5 hours with an extra 9 hours form the charging case before you even have to plug in.
