Charge six devices at once with the Anker PowerPort USB wall charger on sale for $12
The Anker PowerPort 6 Lite 30W 6-port USB wall charger is down to $11.99 on Amazon. This wall charger usually sells for around $18 and was selling as high as $50 a year ago.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The USB wall charger has enough ports to charge all your devices from one location, and three of the ports provide up to 2.4 amps for the fastest possible power transfer. The multi-potent safety system ensures everything plugged in will stay protected, and the device is compatible with international travel. You'll also get Anker's 18-month warranty. Users give it 4.7 stars based on 249 reviews.
