Razer packed every bell and whistle into its BlackWidow V4 75%, including hot-swappable switches
Razer's latest keyboard has a feature list that would make any other keyboard jealous.
You are now subscribed
Your newsletter sign-up was successful
Join the club
Get full access to premium articles, exclusive features and a growing list of member rewards.
- Razer launched its BlackWidow V4 75% keyboard this week.
- The feature-rich keyboard is the company's first hot-swappable keyboard, and it includes several other customization options.
- The Razer BlackWidow V4 75% is available now for $189.99
Razer just unveiled and launched its BlackWidow V4 75% keyboard. The accessory features a keyboard with hot-swappable sockets, tactile mechanical switches, and Razer Chroma RGB. Its customization options allow you to fine-tune your gaming or typing setup. For example, the BlackWidow V4 75% works with both 3-pin and 5-pin switches.
The Razer BlackWidow V4 75% can be bought from several retailers, including Razer's website, for $189.99.
Razer BlackWidow V4 75% | $189.99 at Razer
This mechanical gaming keyboard has hot-swappable switches, loads of RGB, and just about every other bell and whistle you can pack into a compact keyboard.
Price check: $189.99 at Amazon
Razer's BlackWidow family of accessories have high-end specs and pack in several features. That's the case here with the BlackWidow V4 75%. The keyboard has an 8000Hz polling rate, programmable keys through Razer Synapse, Doubleshot ABS Keycaps, N-key rollover, and anti-ghosting.
Article continues belowUnlike its predecessors, the BlackWidow V4 75% supports hot swapping its switches. The keyboard has a socketed PCB that lets you swap switches, including options from Razer or custom switches. Razer Orange Tactile Mechanical Switches ship with the keyboard and promise "tactility without the clicks," according to Razer.
While mechanical keys are often clicky, which is a desired attribute by many gamers, some keycap and switch combinations can create unwanted noise. The BlackWidow V4 75% has a gasket-mounted FR4 plate, two layers of foam, and a tape-enhanced printed circuit board on the FR4 plate to reduce pinging and reverberation.
You can customize the keyboard's look, thanks to its 2-side underglow per-key lighting. Our Razer BlackWidow V4 Pro review said in its title that the keyboard had "so much RGB, God may complain," so it's unsurprising to see the BlackWidow V4 75% have loads of lights.
The price tag of the Razer BlackWidow V4 75% is certainly premium, but that's expected from devices in the range.
Sean Endicott is a news writer and apps editor for Windows Central with 11+ years of experience. A Nottingham Trent journalism graduate, Sean has covered the industry’s arc from the Lumia era to the launch of Windows 11 and generative AI. Having started at Thrifter, he uses his expertise in price tracking to help readers find genuine hardware value.
Beyond tech news, Sean is a UK sports media pioneer. In 2017, he became one of the first to stream via smartphone and is an expert in AP Capture systems. A tech-forward coach, he was named 2024 BAFA Youth Coach of the Year. He is focused on using technology—from AI to Clipchamp—to gain a practical edge.
