A4WP expands Rezence wireless charging spec to power laptops, tablets in future
You are now subscribed
Your newsletter sign-up was successful
Join the club
Get full access to premium articles, exclusive features and a growing list of member rewards.
The Alliance for Wireless Power (A4WP) is announcing an expansion of its current Rezence wireless charging specification that will offer up to 50 watts of power in the future — allowing charging of multiple devices, including laptops and tablets, with a single charger. With upgrades to the base spec expected to be finalized by the end of 2014, A4WP will have Rezence capable of powering laptops, tablets and other consumer electronics with different power requirements.
The Rezence technology will also support a range of charging wattage, from 1-50 watts, allowing multiple devices to charge from one power source at different power levels to suit that device. A4WP points out that other standards are limited in the 10-15 watt range and often only support single device charging. Despite A4WP's technological advancements, it is still falling behind the likes of the Wireless Power Consortium (WPC) and its Qi wireless charging standard in terms of adoption.
Several big-name manufacturers are on board with the A4WP spec, including Dell, Fujitsu, Hon Hoi (Foxconn), Lenovo, Logitech and Panasonic. It should be noted that many manufacturers are part of multiple wireless charging space groups — including the likes of Broadcom, which plans to bridge together multiple specs with single wireless chips.
Article continues belowSource: A4WP
Andrew is a Former Contributor for Windows Central.
